cylinder fix
cylinder fix
Hello !
Here is my next step in learning to put back my 350 back to life ,
fixing 2 leaking cylinder, I will try by myself before giving it to a cylinder shop.
here are my first attempt :
Removing the lock nut
pushing down the rod stopper to be able to remove the snap ring
removing snap ring
pulling out the rod assembly
removing snap ring
Dig in boy !!
J-D 350 straight 1966
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
Mack RB688S 1990 dumper
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
- bigredmist
here is some update
1- fixed my tilt cylinder booth ( leather )
2- remove lift cylinder from dozer
3- remove lock nut and rod guide ( look at the set-up for removing )
4- rod dis-assembly
Booth fix
cylinder removal
rod-guide removal
rod dis-assembly
4- rod dis-assembly
Booth fix
cylinder removal
rod-guide removal
rod dis-assembly
Dig in boy !!
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
Hello !
another set of pics
1- all cleaned properly
2- kit all set-up in order
3- ready for field test
back-up whasher( rubber) top
o-ring bottom
(make sure they are not twisted)
o-ring bottom
cylinder wiper
rod-guide back on shaft
back-up whasher towards threads
then o-ring
large seal first V shape toward flange
the last seal has a flat back shape (so it seals when we put back the piston) opposing to the others that has a groved shape so they fit togehter
rod-guide back on the shaft
O-ring (make sure it is not twisted)
piston
nut back on ( torque according to whish cylinder you do)
rod and rod-guide back into the cylinder
push down the rod-guide far enough to be able to insert the snap ring ( not too far cause you need to put back the lock nut and you need threads on the ro-guide head to do so )
you are then ready to test an then re-install !!
another set of pics
o-ring bottom
o-ring bottom
cylinder wiper
then o-ring
piston
Dig in boy !!
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
- JD440ICD2006
Great pics, thanks for sharing.
Looks like it is as good or better than new. You will never have to THAT again!
Hi !
here is the last update !
the cylinder fix is a total success !!
Man I'm glad
thank you for all the comments this forum is my fuel and I'm glad to participate and sharing with you .
enjoy !
Man I'm glad
enjoy !
Dig in boy !!
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
Users browsing this forum: No registered users and 71 guests
