cylinder fix
andregrondin
cylinder fix
Post by andregrondin » Fri Apr 27, 2012 1:16 pm
Hello !
Here is my next step in learning to put back my 350 back to life ,
fixing 2 leaking cylinder, I will try by myself before giving it to a cylinder shop.
here are my first attempt :
Removing the lock nut
pushing down the rod stopper to be able to remove the snap ring
removing snap ring
pulling out the rod assembly
Dig in boy !!
J-D 350 straight 1966
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
Mack RB688S 1990 dumper
MarkW
Post by MarkW » Sat Apr 28, 2012 7:19 am
So far so good, nothing has stripped or broken yet!
This will be an interesting thread, thanks for posting!
bigredmist
Post by bigredmist » Mon Apr 30, 2012 6:27 pm
Very curious to see your progress. May need to try it myself.
1973 JD450B
Dave
East Moline, IL
andregrondin
Post by andregrondin » Tue May 01, 2012 7:52 am
here is some update
1- fixed my tilt cylinder booth ( leather )
2- remove lift cylinder from dozer
3- remove lock nut and rod guide ( look at the set-up for removing )
4- rod dis-assembly
Booth fix
cylinder removal
rod-guide removal
rod dis-assembly
Dig in boy !!
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
andregrondin
Post by andregrondin » Wed May 02, 2012 6:05 am
Hello !
another set of pics
1- all cleaned properly
2- kit all set-up in order
3- ready for field test
back-up whasher( rubber) top
o-ring bottom
(make sure they are not twisted)
o-ring bottom
cylinder wiper
rod-guide back on shaft
back-up whasher towards threads
then o-ring
large seal first V shape toward flange
the last seal has a flat back shape (so it seals when we put back the piston) opposing to the others that has a groved shape so they fit togehter
rod-guide back on the shaft
O-ring (make sure it is not twisted)
piston
nut back on ( torque according to whish cylinder you do)
rod and rod-guide back into the cylinder
push down the rod-guide far enough to be able to insert the snap ring ( not too far cause you need to put back the lock nut and you need threads on the ro-guide head to do so )
you are then ready to test an then re-install !!
Dig in boy !!
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
Post by JD440ICD2006 » Wed May 02, 2012 7:48 am
Great pics, thanks for sharing.
Looks like it is as good or better than new. You will never have to THAT again!
andregrondin
Post by andregrondin » Fri May 04, 2012 5:48 am
Hi !
here is the last update !
the cylinder fix is a total success !!
Man I'm glad
thank you for all the comments this forum is my fuel and I'm glad to participate and sharing with you .
enjoy !
Dig in boy !!
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
