JD 1010 crawler attachments
- 304thomas55
Did anyone make a backhoe attachment for the 1010 dozer crawler?
Deere did, as well as possiblly some aftermarket suppliers.
- 304thomas55
do you know which backhoe attachments fit 1010 crawler
50, 51, 91, 93, don't remember the numbers of the later hoes.
- 304thomas55
ok I think I've found a 93...thanks
You may want to do a search in the archives here and read some threads about hoe attachments on a 1010- it will be pretty rear heavy, especially with a dozer.
you have to put weights on the blade ....JD had a kit for that i would guess about 600 LBS+....im sure you can find some thing(2 pieces of heavy railroad rail) you can put on the front to keep it on the ground.....with the 93 hoe they even used front counter weights on both the 1010 and 350 crawler loaders
Users browsing this forum: No registered users and 60 guests
