JD 1010 crawler attachments
304thomas55
Post by 304thomas55 » Sun Apr 21, 2013 7:27 am
Did anyone make a backhoe attachment for the 1010 dozer crawler?
Post by Lavoy » Sun Apr 21, 2013 8:21 am
Deere did, as well as possiblly some aftermarket suppliers.
304thomas55
Post by 304thomas55 » Thu May 30, 2013 3:53 pm
do you know which backhoe attachments fit 1010 crawler
Post by Lavoy » Thu May 30, 2013 4:09 pm
50, 51, 91, 93, don't remember the numbers of the later hoes.
304thomas55
Post by 304thomas55 » Thu May 30, 2013 8:26 pm
ok I think I've found a 93...thanks
Post by Tigerhaze » Fri May 31, 2013 9:02 am
You may want to do a search in the archives here and read some threads about hoe attachments on a 1010- it will be pretty rear heavy, especially with a dozer.
Post by jtrichard » Fri May 31, 2013 11:06 am
you have to put weights on the blade ....JD had a kit for that i would guess about 600 LBS+....im sure you can find some thing(2 pieces of heavy railroad rail) you can put on the front to keep it on the ground.....with the 93 hoe they even used front counter weights on both the 1010 and 350 crawler loaders
