jd 350c
switchhappy
jd 350c
Post by switchhappy » Mon Feb 17, 2014 6:56 pm
is the 350c a 24v system or 12v I see the box has a place for 2 batteries, anyone know what size batteries I need..
350c 6 way blade, winch, log arch,,, current 3 year project of being saved and put backgether.. HELP
switchhappy
Post by switchhappy » Mon Feb 17, 2014 7:05 pm
and its diesel also.. thanks
Post by jtrichard » Mon Feb 17, 2014 8:01 pm
12 volt with 2 batteries they are parallel .... looks like 2 batteries was an cold weather option..... 1 group 31P should work fine it is a post type battery 6.75" wide 13" long and 9.38" tall
shinnery
Post by shinnery » Tue Feb 18, 2014 1:29 am
A group 31 works just fine on my 1st gen. CTD Dodge pickup. But then also west Texas is usually a little warmer in the winter.
:lol:
switchhappy
Post by switchhappy » Tue Feb 18, 2014 10:56 am
thanks.. it seems to crank slow like the battery is dead witch I have a 4d out of my cat on it now just sitting on top of the box,.. im gonna run a new ground wire to the tranny housing tonight to rule out bad ground. befor I take starter off to have it checked... poor dozer has not ran in 6 years,, I have smoke but not enough ump for it to fire.. nd before its said, its got all new fuel filters oils and new injectors, just don't spin fast enough like starter is dragging , thanks for the help
Scottyb
Post by Scottyb » Tue Feb 18, 2014 5:14 pm
I would get a little oil into the cylinders before turning it over much more. In through the injector holes, or a few squirts into the either injector plug hole while turning it over should work. I had a engine that sat for many years and the mice filled the engine with canola seed ! I rebuilt the starter as well because it was dragging. Was not needed as we found out. Members here also have wrote that when starting engines that have been left for years that they pump oil through the engine first. Makes sense to me.
backhoe attachment.
Scottyb
Post by Scottyb » Tue Feb 18, 2014 5:21 pm
A long shot but, if your 350c has hoses out back for a ripper or hoe, they have to be connected to each other.
I cant recall if my 350c has a pump disconnect (like my 350b) lever but, if it does, might be a help if you disconnected for the start up.
backhoe attachment.
Post by jtrichard » Tue Feb 18, 2014 6:23 pm
If that 4D is any good it has twice the CCA that deere spells out in the parts book with single battery
switchhappy
Post by switchhappy » Tue Feb 18, 2014 8:30 pm
iv already got oil pressure, and no its not set up for a ripper or hoe, and the battery is new, the ground is good, took off the starter and did the jumper cable test and it hardly spins fast at all.. seems to drag.. mabe a stuck brush, im take it to starter shop tomorrow, he will test it and tell me whats wrong..
Post by jtrichard » Tue Feb 18, 2014 9:18 pm
bushings are shot most likely...sounds like the armature is dragging the fields
Scottyb
Post by Scottyb » Tue Feb 18, 2014 9:25 pm
A starter is an easy fix so if that is your only problem you are in good shape. Bring diesels back to life after such a long time is such a good feeling, I removed the head and cleaned the Canola seeds out of my 350 and.... it started, and ran well after an equally long time. Nice that yours is the c model as the steering clutches will not likely be seized as my old 350 was.(and still is, I bought it for a parts source but have not yet removed any) Here is hoping that your C will fire right up !
backhoe attachment.
switchhappy
Post by switchhappy » Thu Feb 20, 2014 10:41 am
shouldnt have any frozen up clutches iv put every nut and bolt in this dozer so I know there shouldn't be any frozen up parts, only part iv not had to put together was the motor.. it was still together..its in my shop and has been for three years..lol.. as far as my starter goes its good they said.. he tore it apart checked it and said it was in a1 shape, so mabe I have a bad positive wire, iv re grounded, eather that or the cylinder walls have surface rust.. idk..im gonna test the voltage to the starter when I get time tonight or tomarow.. bad thing is, I almost had this dozer started last year when I found out that two injectors were dribbling fuel instead of spraying.. so o replaced all three with new then never messed with it..lol.. now this..lol
switchhappy
Post by switchhappy » Thu Feb 20, 2014 10:44 am
all this work because previous owner thought he could change the trans coupling front the front. then re build the tranny from the front two.. that was a mistake..
